how do I mount transducer on coleman crawdad 12 ft royalex plastic jon boat
robert1965
I want to use my lowrance fishfinder in the boat, how do I mount the transducer, can I make a bracket or something to attach the transducer to?
Expidia
Re: how do I mount transducer on coleman crawdad 12 ft royalex plastic jon boat
Just buy a bracket from Lorance for your model transducer. probably less than $10 and it should come with the mounting hardware too.
Or if the floor is one layer plastic you can epoxy the transducer to the floor inside the boat. Works just as good. Rough up the area a little with some sandpaper. Take some clay and roll it out like a big worm. Press that around the transducer, remove the transducer and fill the little clay pond with liquid epoxy that sticks to plastic. Press the transducer in real slow so you don't get any air bubbles under it. When dry, remove the clay.
NYBo
I don't think epoxying to the inside of the hull will work too well. Adhesives don't seem to stick very well to Ram-X.
I made up a bracket with a suction cup that I use on my Crawdad. Works great!
robert graham
How about a couple of Stainless Steel screws, about 1/2" long?
