Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
I currently have two PCs networked together with a 5 port switch and Ethernet cards. One PC called main has a modem card and is set up with shared internet access (win XP pro). The other PC remote (win 98) accesses the internet via the main PC. With this setup, Main must be on and dialed in for Remote to have internet access. This is fine given the current setup and usage. <br /><br />Ok all you network gurus, here is my problem: I am going to make a change where Main is no longer easily accessible to power on and dial a connection when Remote users want to have internet access. Can I solve this problem by having the modem be independent of either PC and hooked up to the 5 port switch/hub? If so, what hardware do I look for?<br /><br />In addition, there will most likely be a third and 4th PC added to the network in the near future.<br /><br />Where I live, I only have dial up access. No DSL, no Cable, and Satellite is too expensive to justify its use. So I am stuck with dial up. How do I make this work?<br /><br />Thanks,<br /><br />Mark.
