91 OMC OD. I'm replacing the shift cable. When I removed the OD. I see corrosion/buildup around the shift lever.
Will this interfere with shifting?
See pictures attached
Does the buildup mean I have a leak someplace?
This built up in less that a year with the boat only going out 5x. I do live near the ocean and I do take it in salt water
To clean this out, is CLR good enough?
Should I protect with rustoleum or a marine paint? Do I paint the Shift lever (0983898 ) and the bellcrank, shift (09156796)?
Should I seal around the outside of the OD with a marine sealer?
Any other thoughts?
Thank you.
Any other thoughts?
Thank you.
