How Do I Remove a Stuck Gimbal Bearing?
KM7
It does make sense. I do wonder how deep the water has to be in the bilge before it gets up to the drive shaft. Can see that?
Lou C
It would have to be quite high, like above the crankshaft pulley centerline. It actually makes more sense to me that the seal keeps water that gets into the bellows out of the bilge, so a failed bellows does not sink the boat....
rolmops
I remember reading in a Mercruiser service manual that the seal is mostly there to keep the grease of the gimbal bearing out of the bilge. I remember the challenging job of cleaning the grease out of the bilge of a friend's boat. This was after we had pulled the engine. The oil pan was all sticky on the outside and there was that filthy water/grease junk over the bilge. Some of it had even made it to the bilge pump. It was a nasty job.
Scott06
Not really …for water to be up that high it would be at the crankshaft level in the bilge. You would have a starter under water and likely water in the crankcase, least of your concerns would be a gimbal bearing then.
JKLknik
Keep good pressure on it with the puller. Keep heating it then cooling it with pb blaster. Keep the pressure on it.
