How do I remove this stuck impeller key?
jasondainter
Johnson 55hp 1979.
Any ideas how I remove this thing? It looks to have slipped down lower than its supposed to be so cant even grip it...
Faztbullet
Take 2 screwdrivers and pry it up. Appear to be wrong one anyway as should have square slot for key..
Likely has broken / destroyed gears.-----Salvaging the impeller is not a worry.-----Just cut it off.
tpenfield
Impeller usually has to come up first, and if stuck by the key, then pry/cut (carefully) as mentioned.
