How do I safely remove anti-siphon and intake line?
TXGlastron
Hi all. I have been able to remove the fuel line clamp, pull the old fuel line off, and even unscrew the anti-siphon valve. But this square head is my nemesis right now. I want to get it off and check my intake line and filter for clogging. How do I safely remove this? Is it just muscle, or is there a thread seal on this as well? This part is new to me. Thank you.
bajaman123
Terrible picture...
So are you saying you have removed the hose and hose barb and now are just trying to get the 90 degree fitting (the "square head") off? Typically these are brass, and will have some sort of thread sealer on them. Liberal application of Break Free, PB Blaster, Kroil, etc is indicated. Then find an open end wrench that fits the square tightly. After letting the penetrating oil work, rock the fitting back and forth with the wrench...should free up pretty easily.
TXGlastron
Agreed, terrible picture. But you are correct on your assumption. I have removed the fuel line from the barbed anti-siphon. The square head is what is left right now. I didn’t want to just start cranking on it and break something. After I break it free, is it best to purchase a new one? I.e. are these crush threads on the brass? Really appreciate any hints before I start muscling it and ruin the tank.
alldodge
The antisiphone valves are cheap, and just replace it
Normally made of aluminum so next to no chance of sparks with tools on the hex head.
TXGlastron
Terrible picture...
Perfect, thank you. I’ve proven myself to be fully capable of poor decisions. I’m now much more cautious as I learn about boat maintenance.
Lou C
You want to put a thin wrench on that hex fitting that’s on top of the tank to hold it steady when removing the pick up tube. I was able to get mine out & it was in a 38 year old aluminum tank. Go easy on it, take your time..IIRC they are NPT threads.
Bt Doctur
when/if you manage to remove it ,remove the pickup tube from the fitting.It just unscrews the same way. look inside the tube and you may see a SS stent inside the tube, It simply pull out1777725786608.jpeg
