1988 OMC 3.0L Cobra
Seloc Instructions (followed them all):
If the drive has been completely remove from the boat, simply follow the upper gear housing removal procedures and lift it off the lower unit, otherwise:
1. Move the drive to the full down position and the drain the oil.
2. Now move the drive to the full tilt up position.
3. Position an appropriate support fixture around or under the lower unit.
4. Disconnect the battery cables.
5. Make a note of the of where the index mark is in relationship to the grid on the bottom of the trim tab and then remove the trim tab bolt and the tab. Make sure that you write the tab mark down somewhere!
6. Remove the bolt that was partially covered by the trim tab and then remove second bolt forward of this one. The middle bolt is for the anode and does not need to be removed.
7. Remove the 4 mounting bolts (2 on each side) from the sides of the lower unit.
8. Carefully lower the housing down and away from the upper unit until the shift rod disengages the guide pin and then swivel it 90 degrees to port while lowering it completely away. Move it to an appropriate stand.
I can't even separate with a pry bar. Am I missing something?
Thanks.
Thanks.
