njrextreme
- Joined
- Mar 11, 2010
- 228
I have a problem with the tilt on my boat. When I have the motor in the up position and put it in gear to go, the motor gets pushed down. I don't see any fluid leaks but can here the ram leaking from the top seal if I push down on the motor manually. I see a pin at the top of the ram that holds it to the engine bracket but it won't budge. I tried twisting it and pounding it with a punch. I took off the pressure of the pump and have the motor locked in the up position. Can someone walk me thru the steps of removing the hydro ram? I was told I can replace the top seal on it.
