How do I Stop Loosing Bearing Buddys??
KM7
I'm not sure what you are showing here. The outer hose clamp is on the BB. Is the inner clamp on the hub. Do you connect then together somehow? Mine did go in pretty tight using a heavy hammer and a block of wood. Of courst tapping gently at first to get it started square.
JASinIL2006
Looks like a strip of rubber wrapped around the seam between the Bearing Buddy and the hub; the clamps anchor the strip to each part so the Bearing Buddy can't fly off.
