How do I take out my trim Motor on a omc I/O
dm14892
I have a omc 120 HP I/O motor. here is my problem, I had to take out the tilt motor because i found it to be frozen and it was a mess. But got that fixed and not that works great. But went to try the trim switch and all i get is clicking. So im guessing that motor is frozen to, not quite sure. However im trying to take it out and I'm not quite sure how to do that its in the front of the motor and there is 4 bolts under and the motor is connected to some type of gear. and the motor is covered with some sort of rubber, i assume that is so the motor dont get wet. I cant seem to get the rubber off all the way, abd im not sure how to get the motor out so i can check it. or is it my solinoids that could be bad casue their clicking??? any help would be greatly appreciated. thank you<br />dave m
FatBack
Re: How do I take out my trim Motor on a omc I/O
Check your E post from the other day. There should be a hose clamp that holes that rubber boot on the motor. Thake that off pull the boot off and it should be self evident how to get the motor off. Read your first post on this first.
dm14892
Thanks fatback looked at other post so i really dont need the trim motor, thats good cause i took that rubber boot of and cant find and type of screws to take it out. 1 question though, what is the dolphin device you refered to in my last post??<br />thanks dave m
