How do I use Seafoam
alboraso
I have a 1984 9.9hp 2 stroke Johnson. I know there are a lot of threads about Seafoam but it's hard to weed through all of them to get the information I need.I just purchased this motor & it probably has been sitting idle for several years. It seems to run fine & I just had the impeller replaced. What is the best way to use Seafoam for this motor? Thanks.
jdsgrog
Re: How do I use Seafoam
What are you trying to do with the seafoam? If you are going to decarb the motor, then go to the "top secret file" in the Johnson/Evinrude repair forum and follow link to decarb. If you are using it to simply as an addative to your tank, seafoam has instructions of it's use.
