how do you get a dry bilge for the quagga inspection?
ezmobee
Re: how do you get a dry bilge for the quagga inspection?
A fellow moderator has suggested sticking a strip of rag into the drain hole. It will wick the water up and dry out your bilge.
rokrau
Bow up, plug out.
On Anderson there is a small parking lot off to the side, right when you are on top of the hill. I pull up there and lower the drive a few times, there is always water coming out no matter how many times I've done this at home. Scientifically spoken: "The drive to the lake shakes it loose".
The newest drama in Santa Clara county is the "tube inspection" :( This just keeps getting better and better... :(
bruceb58
There was a good point brought up about the water left in the cooling system. what do we do about that? Or is it possable the temp of the system will kill off the bio hazards?
I think the problem would be the water that didn't quite make it up to the engine. The water in the hoses and the coolers leading up to the engine.
