5000 Watts at 12 volts???? That's 417 Amperes! That's a quick way to kill a battery!
Was looking at Harbor Freight Tools and wondering...........
They have 12 volt power inverters up to 5000 watt continuous 110v output.
Would a small window air conditioner from wally world work with a inverter?
Small window air conditioners use around 500 watts. If two batteries hooked parallel powering a 1000 watt inverter. Should work![]()
That's roughly 50 amps from the batteries not counting the 10%-20% inefficiency of the inverter. The inverter will get hot and contribute to the heat load.
Since you should not discharge a deep cycle battery more than 50%, you'll get, at best, two hours of cooling before you have to recharge the batteries. It will take a very long time for your engine's alternator to recharge the batteries from this level of discharge.
My guess is, more like one hour of cooling from 130 lb of batteries.
psst... 500 watts = 4.2 amps@12V, not 50. (amps=watts/volts)
I have AC in my boat but only at the dock.
Away from the dock, I have a hatch, windows, portholes, and an oscillating fan. These (except the fan) all need to be closed underway or water will get into the cabin.
When anchored, the boat will point into the wind unless the current turns it. The breeze is usually enough to make it comfortable. If it's hot, we don't wear a lot of clothes.
We just have a small cuddy cabin on our 21' boat. When anchored we are typically facing into the breeze, and opening the hatch catches it. It's actually pretty cool down there most of the time, but we don't spend a ton of time down there.
That swamp cooler in a cooler thing looks neat, I wonder if block ice or dry ice would work better than cubed?
Dry ice is frozen carbon dioxide and I don't think you want that in your cabin. It's not carbon monoxide which will kill you, but carbon dioxide can displace the oxygen in the air with the same effect.
hehehe, thanks! :redface:
Could dry ice be sealed up somehow as to not release the carbon dioxide?
