1993 200hp carb evinrude. not always, which makes it worse, but sometimes on startup it takes three or four times for the engine to maintain an idle If I give it gas it will just bog down. Bulb is primed and hard. would this condition be indicative of a carb problem, or possibly a fuel pump?? If I am running ( which when it runs it runs good, sometimes some hesitation ) and I shut it off for an hour, I get the same condition, similar to fuel starvation. Carbs always have to be primed when starting, I believe they are bleeding down when left overnight, Ineed to replace float hardware. Any suggestions would be appreciated
