Johnsuki99
Thread starter- Joined
- Oct 21, 2023
- 15
Hi guys
I picked up an old Honda B100s 1983 outboard, and am preparing it for spring. It had water in the lower gear case and a test showed air leaking through the top below the water pump. I have a new seal coming. Part # 91252-935-004
Have a question about how to prepare the mating surface and this oil seal, that sits under the water pump. I did find that the previous oil seal was not in there flush it was at an angle. The lower unit is lowered to work on, but shift rod is still in the motor casing.
Whats the best way to clean the shaft area above the drive shaft bearing, and do you put any kind of sealant on the outside of the oil seal when you push it in? There was no sealant on there when I popped it out. Thanks.
