keithm1961
Thread starter- Joined
- Jan 29, 2010
- 46
I have a 1976 85 hp Johnson, It has gotten, the last two weekends out, where it really doesnt want to idle. If I open the warm idle lever it does just fine but then your locked out of gear. How do I raise the idle at the carb. I looked very quickly and really didnt see an idle adjustment.
I put new plugs in at the beginning of the season. I have to idle for about 10 minutes after start up because the water is so shallow it takes that long to get to deep water. Maybe as simple as a plug change?
If the bleed screw on the tilt trim is loosened the tilt will come down. I rebuilt the valve body all new orings, it works very well. I'm not loosing fluid but the tilt will bleed off slowly, so what I'm wondering if the bleed screw should be replaced because there is a nylon tip on it that is not replaceable, and it could be leaking past that/
