How do you tell the size of your flywheel?
mikey.himself
I've been trying to order my starter and they can't seem to determine which flywheel size my engine has with the engine serial number. The reason is because im buying a new starter.
Old Delco remy starter #19985708, new #9000884.
Engine is Mercruiser 5.7L V8. The engine serial number is #0C332099. Is there any way to find out?
It is in a 1988 Rinker.
Desperate for help!
thanks in advance...mike
f_inscreenname
Re: How do you tell the size of your flywheel?
It's either a 11 1/2" or 14"
What motor do you have?
mikey.himself
Mercruiser 5.7L V8 350.
f_inscreenname
My 1986 454 is a 14" with 168 teeth. I would think yours is the same. Being you already tried one, what size was it for? It would have to be the other.;)
Don S
You have a 14" flywheel. Merc stopped using the 12" back in 85, and your engine is an 88.
mikey.himself
I haven't actually tried one physically, just based on ordering. Poorly set up Mercury's part leaving the parts guy to guess the flywheel size.
When I go to Mercury Parts Express for a parts lookup, they give me 3 options. They are:
STARTER MOTOR (12 IN.)
STARTER MOTOR (8 IN. - 3/4 IN. DIA. END CAP)
STARTER MOTOR (8 IN. 2-7/8 IN. DIA. END CAP)
Is their parts system out of wack? I did notice however that no matter which selection I make, the part # is the same. 50-863007A1
DESCRIP OF PART:
Delco PG260 G, 11 tooth pinion, bottom mount, offset bolt pattern
Fits 1996 & newer GM V-6 & V-8 (305 & 350 cid) engines. Also fits 1999 & newer MCM 3.0L.
Serial Number: 0C332099 Model Number: 457S100AS
Don S
All those different choices are no longer available for buying a complete starter. The 50-863007A1 number is a superseded number to order for a complete starter.
You can still order parts for one of the other starters, but you need to know which one you have.
Reel Poor
If your original Delco starter has staggered bolt holes it's a 14 inch flywheel. If the bolt holes are straight across it's a 12 inch flywheel.
mikey.himself
My delco starter has the offset bolt holes.
Ayuh,.....
Then you need a Stagger Bolt Pattern Marine starter for a Chevy.......
