How do you test a power pack on a 15 hp Evinrude
Banoe
I have a 1996 15 hp Evinrude with ignition problems and I need to check the power pack. Can any one tell me what the ohms readings should be for this power pack?
Thanks
petryshyn
Re: How do you test a power pack on a 15 hp Evinrude
The internal electronics are not testable with an ohmmeter unless the unit it disected (rendering it useless)
The methodology for testing power packs is :
-Give it a appropriate charge voltage
-give it a appropriate trigger
-give it a good coil to energize
-no ground to kill circuit
If it doesn't function with the above.....change it
cheers
