Re: How does an Idle Stabilizer work?
Andy, You can easily remove that temp sensor... And it does measure metal temps... I almost guarantee it!!!! I don't know what you guys are talking about regarding a plastic insert... That thing doesn't need one... It should just be fixed in place with a plate held on with two bolts, the sensor actually threads into the plate... The end of the sensor should rest right up against the cylinder head (underneath the water jacket cover, sealed off from water)... I believe it is recommended that some kind of heat sink compound should be used at the end of the sensor to help in the transfer of heat...<br /><br />Are you sure we are all talking about the same thing? It is brass, and is threaded into the plate with a tan/blue stripe wire connected to it.. The lead is connected to the sensor with a nut on the threads exposed. That lead should go directly to the guage, not the terminal block... However the overheat switch lead does go to the terminal block...
