How Does Clutch Dog Ratchet?
TheDerby
I just replaced the shaft housing on my M140A2 and have everything back together ready for pressure tests.
I checking the shifting I realized that while in forward or reverse I cannot turn the prop any direction. In neutral it spins free.
I'm trying to figure out how the mechanizim allows the ratcheting in the first place. That may point me in the right direction.
Thanks in advance!
Derby
TheDerby
Re: How Does Clutch Dog Ratchet?
Or, can anyone tell me it the Tohatsu M140A2 is designed with a ratcheting clutch?
In forward gear, can you rotate the prop one way and not the other?
Thanks again!
TOHATSU GURU
Do you have a parts diagram or a service manual with an exploded view?
TheDerby
Looks small. let me know if you can read it.
I would imagind in order to slip the dog teeth would have to be chamfered on one side. They are square.
ethanderby@gmail if you need a better picture.
Going home now to rip it apart again. Can provide pics as well.
TheDerby
Guru. do you know if this is a design issue? I took it apart again, poured over the manual and judging by the parts and mech. I do not see how it is possible to ratchet CCW in gear.
Let me know what you think, I appreciate your help.
For what its worth, rotating the crack shaft produces desired results in all three settings, F/N/R.
pongy
It's a dog clutch mate, It is either in or out and shouldn't ratchet
You should just bang it into gear and not gently slide it in or out or you will chamfer the dogs
What your'e describing sounds perfectly normal to me
pvanv
The clutch dog for the 140A is not intended to ratchet.
TheDerby
Thanks guys that is what I figured. I was getting this one confused with my Merc OB.
Again, looking at the parts and how they go together, there is no way for it to ratchet.
After figuring this out last night I ended up just finishing the job. Now ready for some tuna!!!
Thanks again.
