How Does My Water Separater Look?
BoatNoobie
I've only owned this boat for a couple of months. My previous 15 HP motor didnt have a W/S.
This motor is a 2005 60HP 4-stroke. I dont know what is suppose to look "normal".
BoatNoobie
Re: How Does My Water Separater Look?
what is it suppose to look like when it has water in it?
The gas in the tank is ~3-4 years old.....:eek:
wcsd106
If the gas in the tank is that old, I would completely drain the tank it possible, and you might as well change the water separator. It's cheap enough to replace.
BoatNoobie
I thought about draining the tank somehow.
The previous owner bought this boat back in 06 with a full tank of gas. I bought it last month. It still has about half a tank of gas from the original tank of gas.....:eek:
But the motor runs beautifully. Pulls strong with no issues. So I think the gas might be ok. I know additives were added yearly.
milehighboater
Do you have any concerns about it other than the plastic is slightly yellowing? I think everything looks good.
Blevins
Uif it had water in it then the water would sit at the bottom and would be clearly visible. I would recommend changing the filter simply due to debri. If the gas is 4 years old it probably has little to no ethanol in it but it's octane level may have significantly dropped I wouldn't necessarily drain all the gas I would add new gas on top and try an run her for the better part of the day and get the fuel running trough it.
BoatNoobie
Not really. Just wasnt sure what I'm suppose to be seeing.
