how far back
murrayfish
I'm working on a trailer for my F-18 and wonder how far back the boat should sit in relation to the last roller? And also how to locate the wheel location front to back. It's a single axle trailer. Here is the only picture I have at the moment. That is the donor boat at the dump.
NYBo
Re: how far back
The last roller should be within a couple of inches of the transom.
EddiePetty
Re: how far back
After the hull is adjusted to the last rollers, re-position the bow stop of the winch stand just above the bow eye. Then position the axle to provide approximately 10% of the total weight of the loaded trailer on the tongue.
murrayfish
Re: how far back
10%? My boat is 2800lbs empty.... I can't see a tongue weight of 280lbs...
superbenk
Re: how far back
I can tell you with confidence that, based on your picture, as it currently sits it's WAAAY too far back :D
roscoe
Re: how far back
Get yourself a nice heavy duty tongue jack.
So wet weight plus trailer is going to be 4000# ??
Yes, 300-400# tongue weight.
You are still talking about pushing 4000# around by hand, but at least you won't be trying to lift it at the same time.
I think you better plan on using the truck.
UncleWillie
Re: how far back
Something I could move without a truck. Seems I need to do some reading.
If the Boat is 2800 lbs empty it will be well over 3000 lbs with fuel and minimal gear.
Add another 700lbs for the trailer. Puts you at 3700+ lbs ready to roll.
10% would be more like 370lb. 7% is still over 250lbs.
You're a better man than I am if you can lift that by hand for more than a second.
The trailer likely has a tongue jack with a wheel that will make moving it possible without the truck.
Alwhite00
Master Chief Petty Officer
Re: how far back
What roller? Looks like a bunk trailer.
LK
86 century
Ensign
Re: how far back
The 10% rule will keep you from getting the sways on the down hills or starting to bounce on a hard stop making your rear brakes useless.
I know it may sound excessive but the the draw backs of a little to much tongue weight are far easier to deal with than not enough.
kenmyfam
Re: how far back
Believe the required tongue weight thing. It is great and accurate advice.
murrayfish
Re: how far back
OK, OK... I'll do 10%.
I have experience with a lite tongue on the road. I was towing a small car on a flatbed trailer one time, i hit the breaks because some dumb *** cut me off. The whole trailer started to fishtail/whip back and forth. The more break the worse it got. I was on the freeway and was able to hit the gas and pull it in line then pull over and relocate the car...
So i do know the pitfalls and will do the safe thing.
Thanks everyone!
JoLin
Re: how far back
10% is a good ballpark figure, but it's even better to read your vehicle owner's manual. In my case (small car, small boat) Mitsubishi recommends between 5 and 10%. Once I adjusted my boat to sit at the right spot on the trailer (transom about 2" aft of the last rollers), the tongue weight was right at 8% of the total.
