How far can boat stick off back?
TxHorns
I have a 23' center console with twin outboards mounted on the transom. I don't store it on the trailer, but do use it every once in awhile. The bottom side of the hull sticks off the trailer about 1-2 feet - is this an issue? If so, how bad of one? Thanks.
oldjeep
Re: How far can boat stick off back?
I would think that you want the transom sitting on the bunks since that is where a huge share of the weight is. Every trailer I've owned the bunks have been even with the transom (nothing hanging over)
Capt21
Thats an awful amount of weight sitting unsupported. Add in a few bumps, and yikes. Most of the weight is going to be on the 10% of unsupported vessel...especially running twins. Taking a chance IMO.
HAV2FISH
Boat should be sitting on the bunks at the transom. The transom should be supported fully by the bunks. You might have to move the boat further up on the trailer or extend the bunks. If you move the boat up on the trailer make sure and check the tung weight. Also make sure the boat fits that trailer, thats a lot of boat to stick off the back.
TxHorns
Thanks for the help. the trailer doesn't fit the boat well at all, but I really just use it for towing it to the shop and back (rarely hopefully) and home and back. I also use a tiedown in the front in addition to the eye strap.
I could just put new boards on it to extend the bunks, but does that do much if they still extend beyond the support/end of the trailer?
dwco5051
Yes it will help support the load of the boat evenly and not stress the hull. It will not change the tongue weight and if that much of the boat is towards the back you could be dangerously light on the hitch. As per previous post check your tongue weight. It should be 10 to 15 percent of the total weight of the loaded trailer.
fishingman220
could you move the winch post foward and adjust the bow supports?
TxHorns
Come to think of it, I can't remember if the winch post is welded on or bolted on, but I'll take a look when I'm down there this weekend and try to adjust it if possible. Otherwise, I'll just get longer 4x4s for the bunks.
Also, I keep my boat in dry storage... this is making me think I need to go make sure they aren't screwing me and putting me on a short cradle.
dave11
Unsupported so much weight might put a hook in the hull.
dingbat
Depends on the boat.
If you own one of those paper mache boats then you might have an issue. If not, then you should not have a probelm.
My last boat sat on a trialer with a 1' overhang for 25 years. Boat manufacturer said no problem. Transom and motor is still attached, hull isn't hooked.
Silvertip
Honorary Supreme Mariner
Extending the bunks two feet from their last attachment will be of little to no help because they simply bend under the load. Move the winch post forward. In your case, having incorrect tongue weight is far less an issue than having that much weight being unsupported.
txtoyman
Like dingbat said - unless you have a pretty soft hull I wouldn't worry much about it. Many, MANY boats spend their lives supported by 2 slings in a boat house - don't think we'd see this as a continuing practice if it caused problems. JMOO
TitanTea
My boat over hangs about 3 inches...No problems.
NSBCraig
Hanging a boat in a boat house isn't anything like a boat on a trailer.
The boat house doesn't move and shake and hit pot holes or curbs it just sits there.
Simple answer the boat should have it's transom supported.
Your trailering only once in awhile and not far it's your choice and probably won't be a problem.
But just cause it works or someone told someone it's ok doesn't mean it's right or should be done.
txtoyman
Conversely - just because someone tells you it is wrong doesn't make it so.
NSBCraig
And just because you refuse to agree with something even though it's true doesn't make a bit of difference in the world around you except in your head.
If you feel the need do some research and you'll figure it out.
Utahboatnut
Maybe you could move the stop forward a bit, extend the bunks AND have a small piece of angle welded from the trailer to the end of the new bunk board. Might not be exactly right but it would atleast provide some support, just extending the bunks will do nothing.
Home Cookin'
short haul/short term, don't worry about it. As Silvertip said, tongue weight is most important.
Ever see big motors mounted on an extension bracket? Ever see that bracket or the motors supported? If 18" of solid boat was an issue, they wouldn't trailer with 2' extensions.
Plenty of other things to do or worry about. Good question, though.
Oh, and hanging boats can deform.
NSBCraig
Actually if you look at those boats with big motors and brackets you'll notice that the transom is supported by the bunks on the trailer.
Any part of your hull is not the same as your transom, your transom is designed to carry the load of your motor(s) not your hull a couple feet forward of it.
Not supporting your transom on your trailer IS the major cause of hook developing in your hull. So what if you never saw cracks or think that anything is wrong, distorting the most important part of your running surface has big effects on how your boat performs.
Your boat is plastic and no matter how much you reinforce it if you abuse it, it will distort.
