Re: How Fast Should 50hp Evinrude Lark Move My Pontoon Boat
You know i never did do a compression check because it did run so good Maybe i should,both plugs are firing as they should.When i first put the motor on, it throttled up quickly and had a ton of power but now that you mention it when i took it out today it seemed to run just as good but a lot less power,i did notice when i first went to speed up the lever wouldnt move so i shut it off and restarted it. The throttle moved as it should,but with hardly and top end power
