how fast???
badjohnson
what speed range should i expect? have an 18ft fourwinns fish n ski with a 150 johnson. at last use i got around 48mph i think rpms were 5000-5200.<br /><br />i will do some testing soon, boat is currently in for repairs.<br /><br />also, has an alum. prop right now( not sure what size), i will eventually put stainless.
ZmOz
Re: how fast???
Probably 55-60 MAX with a stainless prop and in the best conditions. My 16' Glastron with 150hp will do 50mph GPS with an aluminum prop, probably around 55 when I get a stainless.
teamstromer
Re: how fast???
my 18ft alumacraft navigator cs boat with a 90 merc tops out at 45mph, i realized that is pretty fast to be going on the water. i keep her to 25/30.<br />teamstromer
ZmOz
Re: how fast???
Yeah, my grandma keeps her crown vic under 30 too. :p
youngboater
Re: how fast???
How does the Stainless Steel prop make the boat go faster? I have a Lund 16.5' w/75 Mercury 2 stroke (max is 90HP) and an aluminum prop and it does around 40 MPH. THanks any little bit helps.
D
DJ
Guest
Re: how fast???
youngboater,<br /><br />An SS prop has less blade flex thus more energy can be transferred into propulsion.<br /><br />The advantages can be minimal.
youngboater
Re: how fast???
What would you expect on this set up (performance wise)???
dude33333
Re: how fast???
the higher strength also lets it have have thinner blades for less frictional resistance
