How Hard Is A Lower Unit 2 Replace
REPPINSWAPREAM
Hey Guys I Need Some Help, I Want To Remove My Lower Unit But Ive Never Done One Before. Im Mechanicly Incline But I Dont Want To Run Into Any Problems. Any Advice Should I Even Try It You Tell Me. Its A 88 115 Mercury ,thanx In Advance
Barnacle_Bill
Re: How Hard Is A Lower Unit 2 Replace
Pretty easy. 5 bolts total. 2 bolts on each side and one under the trim tab. Be sure to mark the position of the trim tab so you can put it back at the same angle. Shifter is on a splined shaft so there is nothing to do there.
REPPINSWAPREAM
THANX bHILE that helps out alot . let me ask u this if im not gonna put it back on the same motor do i have to mark it.....thanx in advance
