How hard is it to swap power heads
v8psp
I have 2 late 70s model Mercury inline 6 115hp engines. The one on my boat has a hole in piston 3. I am just wondering what all is involved in swapping the whole power unit. Any details are greatly appreciated. Thanks in advance
Laddies
Banned
Re: How hard is it to swap power heads
it is best to drop the gearcase before pulling the powerhead. Also, you will need to pull the powerhead straight up about 1 foot to clear the mounting studs and lower cowling. You will need a hoist of some kind to do this. I use a really cheep block and tackle which I bolt to the garage door header and use plumbers strap to attach the other end to the flywheel bolts.
mmf
better make sure to purchase a new gasket before you tackle this, otherwise you might have a large water or exaust leak.
v8psp
Where do you guys recomend getting these gaskets?
