how long is gas good for
brian3127
i winterized my boat last year and put stabil in the gas tanks it had a half a tank left. i ran it a couple times this year. but havent been out for about a month and a half now. i have alittle over a 1/4 left is that gas still good. should i empty the gas out of it and put new in it our would i be alright if i just add new gas to it.
roadrunnr
Re: how long is gas good for
I typically add to the stabil fuel at the beginning of the season. I wouldn't hesitate to just add at this point either, especially at around $4.00 per gallon. I don't think you would have any problems. I once, when my son was a new born, left my boat in storage over a summer. The next summer I simply added to whatever was left in the tank and didn't have any problems. Maybe somone else has different opinion or better reason for replacing your fuel. You didn't mention how big your gas tank is, but a quarter tank is nothing plus you already ran it on last years fuel and didn't mention that you had any problems with it.
5150abf
I read in a motorcycle magazine that gas doesn't actually go "bad" for a year or more if it is in a sealed container, I would think if you put stabilizer in just put fresh gas on top of what is there and you will be fine.
brian3127
ok thanks yeah its a 6 gallon tank i will just add to it then
fortyfreak9
I had 10-12 gallons of 2-3 year old gas and I just siphoned it out, put it in my chevy truck and went boating!
DRIFTER_016
I brought my boat out of storage after 7 years this past spring. It had a full tank of 94 octane with plenty of stabilizer in it when stored. I had no problems with this fuel. I have used up this tank and too many more since with no ill effects. I think if it's properly stabilized it is good for quite a while.
Woodnaut
Just a thought, but you might consider waiting until the start of next season before you add any more gas. That way, the gas you are adding will be fresh and the mix you end up with (several months from now) will probably be the best. Either way, make sure you put in some more stabilizer when you add gas.
Nandy
Well, the other half will tell you to fill your tank to keep moisture out... I know, im evil!!!
fishmen111
Gas starts breaking down after a week. On the 8th day, call me at 1.800.555.2976 for pick-up and proper disposal.:D
zach103
hahah.. yah i think youll be fine.. especially after drifter had his for 7 years.. last summer about this same exact time. we stopped using the boat. left the gas in it. no stab with the vent open too. left it. than in about may. we started it. 2 trys. only cuz i forgot to put the kill lanyard back on
Boat Drinks
ETHANOL is not a friend of motors made before 1992. It eats up the fuel hoses and removes varnish from the carb surfaces and clogs the jets. We get 10% ethanol now and it's creating a lot of problems with outboards in a short period of time. I read that without stabilizer gas is doing bad things after only 3 weeks if it contains ethanol.
