jimmbo
- Joined
- May 24, 2004
- 14,096
On the plus side - Figure Skating would not be clogging up the TV schedule. :lol:
Neither would Hockey
Thanks guys - I was worried water's properties might have changed. And no hockey? That WOULD be cause for concern
Thanks guys - I was worried water's properties might have changed. <snip>
And air doesn't freeze until -461F
... at -461 degrees F, a damaged driveline is probably gonna' be the least of any of our concerns.Since air is 79% nitrogen and 20% oxygen it most likely can become a solid.
Especially since that temperature is 0?K...absolute zero. This is lower than outer space.... at -461 degrees F, a damaged driveline is probably gonna' be the least of any of our concerns.![]()
ok, so I had to look up the official air temp
Oxygen freezes at -360.9 ?F, nitrogen at -346.18 ?F, and argon at -308.7 ?F. Therefore, air will freeze if it gets cold enough to freeze oxygen. Such temperatures are never reached naturally on Earth
Except in Canada.
My wife can get a room to those temperatures without any sweat at all.
Rick, does Mrs Stephens read these posts?
I'm guessin' Not,.....
