how long will my battery last
Status
Not open for further replies.
russelln114
Hey guys. I have a fishing light that draws 8amps. My battery doesn't have a amp hr raiting. It's a group 27 and all it has on it is @23amp average 175 minutes. The battery is a deca dual purpose. How long will my halogen light drawing 8amps last? And how do calculate the amp hours and rc for my battery. Any help would be great thanks.
wifisher
Re: how long will my battery last
23A times 175 min = 4025 AH
4025 / 8 = 503 min.
keep in mind that your battery may not be 100% anymore and therefore not last as long.
russelln114
Thanks. That was fast. How long will the 8amp light last on a battery that is 75amp hr with 100 Rc?
russelln114
Ok. I'm pretty confused so let me start over. I want to run a halogen light that draws 8amps. I have two batteries one says 75amp hours with 100rc group 24. The other one says @23amp average 175 minutes group 27. The website i'm getting the light from has a chart http://www.fishinglightsetc.com/RunTime.html the light i plan on getting is the 100w aquastar. On the chart it says that i would get 14.4 run ours on a battery. Can someone tell me how many hours i can get off of each battery drawing 8amps constant? I will only be running the light off the battery. Thanks
Fireman431
What ever numbers you get are going to be less than accurate unless you know that the battery is brand new and will have a full & complete charge on every outing.
If you wanna know how long it will last, hook up the light and start the clock. Unhook it when the light begins to dim & recharge.
Silvertip
Settle down and put your thinking cap on! You are throwing a bunch of numbers around and trying to make all of them come out the same. The only constant you have so far is that your light will draw 8 amps of current.
Lets start with the simple one first: You have one battery rated RC = 175 minutes @ 23 amps. (RC = reserve capacity).
Your light draws 8 amps. Think about the 23 amps. Isn't 8 amps roughtly 1/3 of 23? (8x3=24). So that battery would provide 3 times 175 minutes which is 525 minutes (or if you divide that by 60 minutes in an hour) that comes to 8.75 hours. Again, understand that you are only drawing 1/3 the power that the battery spec indicates. Therefore the RC (175 minutes) can be tripled. However, that is an absolute maximum and highly unlikely to run that long. 7 hours and perhaps a bit longer is possible depending on the age and condition of the battery. What the reserve capacity means is that battery can deliver 23 amps for 175 minutes before it is no capable of doing so.
On the other battery rated at 75 AHr, that means it can deliver 75 amps for one hour, put another way, 1 amp for 75 hours. Again, your light draws 8 amps. This is roughly 10% of the 75 amps so using that number the battery would last somewhere in the 7-8 hour range which is again maximum.
WATTS: This number is very different than AMPs and VOLTS but is just another measure of power consumption. W(watts)= E(volts) x I(amps). So 100W divided by 12.6V = 7.9 Amps. Funny how a light rated at 100 WATTs is the same as one that is rated at 8 AMPs eh?????
bruceb58
Also, you really never want to draw down your battery past the 50% point so divide all the numbers you get by half.
For the 175 hours at 23Amps its basically a 66 Amphour battery. 175/60 * 23 = 66.
jhebert
Ensign
4025 / 8 = 503 min.
This kind of calculation shows why the United States ranks 48th in Math education globally.
bruceb58
No kidding!
I was looking at that and shaking my head as well.
This is a case where its probably good to let someone else do your taxes.
Status
