Re: How many miles per $
Howdy y'all,
The number of miles per gallon is really an automotive number since we frequently BUY fuel on a dollar PER gallon basis.
If you're going to buy 1lb cyls, you're basically buying them on a Dollar PER lb basis.
If you want to compare apples to apples, the you really have to figure out how many dollars per POUND you're going to practically spend using either fuel to decide which is more economical, THEN decide if it's practical or convenient or a hassle, etc.
That requires a bit of simple dimensional analysis.
Gasoline is rated at about 114,000 BTU per GALLON and weighs about 6.25LBS per gallon.
LPG (propane) is rated at about 92,000 BTU per (liquid) gallon and that gallon weighs (approx) 4.25 lbs
It's interesting to note that Propane's energy density (BTU/lb) is actually HIGHER than gasoline.....(but NOT by volume)
Propane 4.25lb/gal-- approx 21,560 BTU/lb
Gasoline 6.25lb/gal-- approx 18,240 BTU/lb (this includes all grades of AVGAS too and really is UNAFFECTED BY OCTANE NUMBER)
[Diesel 7.2lb/gal by the way has approx 138,000 btu/gal or 19,166 btu/lb]
If a propane fueled , spark-ignition engine CAN have higher compression and more ignition advance, it COULD approach the same (or maybe exceed slightly) the efficiency of a gasoline (petrol) fueled engine.
So then one would want to know the approx price PER LB of the fuels so you decide if you want to hassle with the different storage problems.
The current price for gasoline around here is approx $3.60-4.00 per gallon (
Which IS $0.58 -- $0.64 PER LB )
Propane purchased by the 1 lb container:
I checked Walmart and Home depot locally. Walmart, $5.37 + tax for (2) = $5.85 OR
$2.92 PER LB
Home depot was $3.25 + tax PER POUND!
Most of us would conclude that using propane by purchasing 1lb containers, is NOT cost efficient by ANY STANDARD!
Ok, so suppose you go to your local propane supplier (assuming you DO NOT HAVE a 500 or 1000 gallon home propane fuel tank)
The local CENEX supplier told me that they charge $2.19 (cash) per gallon to fill a 5 gallon (20lb) container. (they didn't say if tax was included or not)
NOTE: they will only put about 4 gallons in a 5 gallon container +/-
This calculates out to $0.51 PER POUND
So the REAL difference .............
$0.51 per lb[LPG] vs $0.58--$0.64 per lb [PETROL/gasoline]
A "20lb" LP tank weighs about 19lbs..........ADD approx
4.1 gallons of liquid propane and you add approx 18-19lbs for a total of 38lbs to lug around and place in your boat!
A standard 6 gallon (plastic) fuel tank only weighs a few lbs empty and with
6 gallons would weigh approx the same.
I also found a company that makes aluminum forklift tanks. 5, 8 and 10 gallon tanks. The 8 gallon tank filled to 6 gallons LPG would weigh nearly 50lbs.
So, considering approx the same efficiency, (which is probably a "stretch") I would probably still choose the petrol fueled 4-stroke cycle engine)
[QC....check my math!!
ymmv.......
Rick
