Re: How many ounces of freon in a 1994 Maxxima?
the air powered vac pumps from harbor freight will work, but they are noisy, and you need a compressor that can deliver the CFM that they require to do the job. as for the amount needed, there will be a sticker under the hood that gives the exact spec. Keep in mind that if you are doing a system with R12, that it is controlled, and gauges and hoses may not be the easiest thing to get ahold of. Consider doing a full system flush (should do this after a compressor failure anyways) and converting to R134a. this is uncontrolled, and the gauges and refrigerant are much easier to get ahold of.
