Re: How many volts to battery at idle??
what type and what brand of multimeters are you guys using?? My Fluke DMM never reads wrong due to a low battery (never reads wrong ever!). If you are use analog meters then the battery shouldn't even worry it, the battery on those is for OHM's measurement only, as for DMM's, any good quality meter should still be acurate even if the battery is getting low. IF it is causing problems with the readings, I have difficulty believing you would even be able to read the LCD. <br /><br />P.S. I have 12 years of Electronics servicing and manufactureing behind me, so I do know what I'm on about when it comes to test equipment.
