oxbeast1210
Thread starter- Joined
- May 14, 2010
- 309
TE150SLCEM 1989 evinrude xp tracker 150hp
hi guys i was wondering if there is an easy way to tell if i have a 35 amp stator or one of the ones with less amps . I believe it has been replaced
before I owned it but I'm not sure The reason im wondering is because the regulator rectifier is cutting in and out sometimes it will charge and the tach will work but only for a little bit. i was just wondering if i could get the non water cooled rectifier or if it is ok to use the smaller one that bolts to the side?
thank you!
thank you!
