Re: How much anchor chain?
No offense, but this piece of information is incorrect. As stated earlier, the chain changes the angle of pull to a more horizontal and keeps the anchor set. True the boat will need to lift the chain off of the floor which reduces the force placed directly on the anchor itself, but this is not for 'shock absorbtion' purposes it's to ensure the anchor remains set.
Maybe that may be true, but in the big/little scope of thing's the weight of the chain vastly decreases the sharp and agonizing abrupt stop you feel if all you were using was just a chunk of rope.
For example if you are tied of directly to the anchor with an anchor rode with no chain, and tied of to shore tightly, how much play are you giving your boat every time it rises and falls from an incoming wave???
On the other hand if you have sufficient chain/fiber rode out to the anchor and tied of to the shore, do you not think that the weight of the chain vastly effects that abrupt stopping feeling.
Put out 60 feet of chain (real chain not that little girly man stuff), tie it to the base of a tree, climb up a 40 forty foot ladder and pull it tight.
heavy EH.
