Re: how much can you do with prop options
well I don't know if they still do that here but im assuming it is, the way it used to work is you buy the prop since they all cost the same then you start with an average rule of thumb pitch, then you swap it out up or down in pitch size until you find just the right pitch, but as you say, provided its not damaged in any way.
and just to be clear about it, for the prop I do select it should be ... what sized rake? 0? 15? 20? these are the only rake sizes I have seen mentioned so far on the prop websites I have seen.
I never new rake mattered and its hard as hell to find the rake listed on most props so how do I know what rake it is if it isn't listed any where?
I really want to know what rakes to avoid buying for it
heck yes... if you can get loaners that is perfect..... around here you have to buy em and as long as they don't get one single mark on em you can exchange..... I would say go ahead and test with the current prop 1: because you already have it so it costs you nothing except a few minutes of your time, and 2: so that you (and we) will know what and how much the improvement is.....
