How much cranking should a fuel pump need after a carb overhaul?
btravlin2
Howdy.......I've been having idle/low speed problems with my 318: sputtering, stalling, missing, acting fuel-starved. So I rebuilt the carb. No change. I put it back on and after some cranking it fired up and idled smoothly for about 10 seconds. Then I couldn't keep it running.
I torn it down again to double check it, and when I put it back on I also installed a transparent inline fuel filter as a second filter after the new fuel/water separator. I started cranking 5 seconds at a time. This went on for about a dozen tries. No fuel was entering the inline filter. I switched tanks, with no change. I took the fuel/water separator off and there was only a little bit of fuel in it. I can't imagine a fuel pump (mechanical) requiring that much time to do so little.
So I ordered another pump, as the only thing that made sense was the pump had failed. It was old anyway.
Am I correct that a good fuel pump should have gotten fuel to the carb fairly quickly? This is a 22' boat and the tanks are close to the motor.:confused:
Re: How much cranking should a fuel pump need after a carb overhaul?
It may be the fuel pump, but also may be a problem with the new filters you installed or perhaps the fuel line got blocked during installation. Recheck all your work.
Oshkosh1
Ensign
Did you install the new filter with the correct size inlet/outlet barbs for your fuel line?
Fill the F/W cartridge with gas prior to installing it...acts as a priming of sorts.
Squirt some fuel into the carb and try to get it running a little at a time to "prime" it. I used an old BBQ sauce bottle with gas in it. I had to fire it a couple of times before it stayed running.
