Hello again,
As I mentioned on another post I have going. I have found that lower unit gear case was not bolted shut and it came open. And so I used it 3 times without knowing. ( I know this because the outboard was not new as I accepted it as an exchange for another outboard that needed repairs but was told by (chinese storemen) that it couldnt be repaired. I finally found out when the shear pin broke and when repairing it I noticed that the gear case cover/face plate had popped out/open. When I looked inside I found gear case empty of oil with residue of salt water and basically starting to rust. So what I did was flush the gear case out with hot water which revealed sand, salt water, salt residue, rust and maybe a speckle of oil. I then wiped it dry as best I could with paper towels and it seemed to be pretty clean in there. So I closed up the gear case and bolted it shut then put gear oil in it and put prop back on. Is there anything else I should have done or will that do? And how much damage would that have done? I mean it still works so???
Thanks
Marty
Thanks
Marty
