How much does gas weigh?
Sea Mitch
This might be my last year with the 23' Grady 232. It cost $3200 for the slip and $1200 for winterization, wrap and storage. I could get a nice boat each year for that money! Anyway I am trying to figure out the heaviest boat I could buy that my Honda Pilot (4500# rated) would pull. I added 600# for the engine, about 500# for stuff and I need to know how much gas weighs. Is there anything else? How about the trailor?
rolmops
Re: How much does gas weigh?
It is a tiny bit lighter than water.just enough to make it float.For practical purposes you can just assume its weight as equal to water.
JB
Single axle trailers can weigh anywhere from 500# to about 1000#, FB. Dual axles are heavier.<br /><br />Water weighs about 8# per gallon and gas is lighter. I would figure on about 6#/gallon.<br /><br />Good luck. :)
qaztwo
gas various between 6.1 and 6.3 pounds per gallon
rwidman
Have you considered keeping the boat and getting a larger tow vehicle? There are places you can go in that boat that you won't be able to go to in a smaller boat.<br /><br />
Leaded gas weighs more? :D
Sea Mitch
I did consider it. The boat has a 9'6" beam. I was reading the posts about oversize permits and it seemed like it'd be a problem to trailer around. I don't know if because it's big it'll be harder to launch than a smaller boat, I figured a smaller one would be easier to handle. I'm gonna have spousal trouble with a boat in the driveway let alone a truck to haul it with, but I can handle the slack! Any comments are appreciated. I love the boat and don't really want to downsize. Is it that much harder to launch a bigger boat as long as you have the proper vehicle?
byordy
Six pounds per gallon is used when calculating weight and balance for aircraft.<br />Bill.....
jtexas
Originally posted by byordy:<br /> Six pounds per gallon is used when calculating weight and balance for aircraft.<br />Bill.....
Analyzing fuel burn on commercial jet aircraft our rule of thumb is 6.6 lbs/gal for jet-A fuel.
byordy
Yep.<br />Jet fuel is heavier that 100LL Avgas.<br />Bill....
Captn Dave
It's not that much of a hassle launching bigger boats once you get the routine down.<br />But with the weight of the boat, motor, gas, supplies and trailer, you'd probably be exceeding the Honda's limit. <br />Also the permits for wide loads, I believe, are only temporary, but I'm not sure about that.<br /><br />Something to consider, depending on how often you use your boat, is that you may end up using it less if you trailer it. Especially in the shorter seasons in the Northeast.<br /><br />I grew up and lived most of my life on Long Island. After having the slip fees increase year after year, I went out and got a trailer and truck. Even though this made it convenient when I decided when and where to use the boat, I found out that I used it a LOT less. There's a big difference when you can just drive down, hop on, throw the lines and head out. I trailered for three years abd then went back to a slip.<br /><br />I live in Florida now and I'm back to trailering. But that's the norm down here. The ramps are far superior to what's on LI and also the season is so much longer. <br /><br />That Grady 23 is a nice boat and I'm sure you'd like to hang on to it.<br />Another option would be to get a trailer and store it at home during the winter and rent the slip for the season. The Honda should be able to handle it for a couple of trips a year.
Sea Mitch
Thanks Wave. That's great advice. If you are right (and I find nothing beats experience), in three years when it's time to return to the slip because convenience wins out over money, I may not be able to find a slip around here! There are 3yr waiting lists in most places. I think that's a good idea. I will look for a trailer and winterize it myself next winter. This ought to give me a sense of what it'll be like to trailer it and I'll save a little money. Thanks again!<br /><br />At 6.5#/gal it'll hold about 1000# of gas. Filled up it would weigh 7000# with gear, gas, trailer and engine. I wouldn't want to tow that around every weekend I don't think' At least I don't see too many (any!) people doing it.
levittownnick
150 gallons is a lot of gas. A trade-off may be that you carry less gas, say 75 gallons to save some weight, that is unless you use near your capacity on a typical day. An other consideration is that you can save a few $ by fueling at a local gas station.<br />I have been trailing since 1970. I like that the boat requires less maintaince and is at my house. It is true that it gets used less, and that you need a good trailer & tow vehicle. There is a down side to almost everything.<br />Good luck.
Barlow
Originally posted by First Boat:<br /> .....<br />......<br /><br />At 6.5#/gal it'll hold about 1000# of gas. Filled up it would weigh 7000# with gear, gas, trailer and engine. I wouldn't want to tow that around every weekend I don't think' At least I don't see too many (any!) people doing it.
Hi First Boat- No problem if you've got the right tow vehicle and the space for it! Here in WI during summer months folks are 'yanking' their (larger) boats all over the place. I know around a dozen or more folks that do it w/o batting an eye.. a few of those rigs are 40'ers and generously double the weight of your G-White 232 - nice boat by the way!.<br /><br />anywho.. on the practical side of things you'll be able to yank it around W/O much more hassle than you would with a smaller craft.. you'll just need to be a bit more cautious and aware of where it is behind you..<br /><br />get a tandem axle trailer and a 3/4ton chassis vehicle with sufficient torque/tires and suspension and you've got yourself a rig-and-a-half! <br /><br />as they say in Jamacia : " NO PROBLEM MON.." :D <br /><br />If you're looking for less hassle in a smaller boat.. good luck!.. they're all a hassle at some point :D ;)
