How much HP can this boat take?
adamkosecki
I'm about to finish up a project that I almost finished about 3 years ago, before moving out of state for said time. It's a 13' aluminum boat. All that's left is some interior paint, rebuilding and putting wood on the transom, and a good wash.
And get a motor. This boat was rescued from the garbage so I have no idea what make / model it is. There are no manufacturer plates and no max HP label. I have no idea what I can put on here. There was a 35 HP Evinrude Big Twin near the boat when I picked it up, but I'm not even sure if it was ever on this boat. Plus, I think it was a long shaft motor, this is a short shaft transom.
I'm looking at a nice used 40HP motor, but I don't want to rip my transom off. Is that something I need to worry about?
I'd like to note that I have hardwood floors made that are not in this picture - they were stored inside :)
tashasdaddy
Re: How much HP can this boat take?
the 35 was probably on it, a 40 would be really nice. i would put a 1/2 inch sealed plywood motor pad on the outside of the transom. it is just a cushion for the motor to sit on, and not damage the aluminum.
adamkosecki
The inside had some wood running across the back where there is no paint now - I'm going to replace that with hardwood of the same dimensions.
The outside had an Isosceles Trapezoid shaped piece of plywood on it where there is no paint. I was also going to replace that. I assume that's what you're referring to?
I'm still worried about losing my transom, at least when trailering. Am I being a dork?
adamkosecki
Yea, I was going to do that. I don't need to t worry about 40hp being too much power for this small aluminum boat?
Thanks,
Adam
Joe_the_boatman
Thanks,
Adam
If you can't find a comparable boat (and its rating plate), I'd follow TD's suggestion that the 40hp should be alright.
MadProps
this should help:)
adamkosecki
Dah! I got 63 for my value. That points towards just a little over 30hp is acceptable. Now I'm even more unsure about buying the 40hp motor!
larky
don't sweat it, the 40 hp should be fine
Ezrider_92356
i bet the coat guard formula would probably come out around 45 if anyone rembers the link to that.
