Re: how much hp do i need
Should be if its a basic utility style, but maybe not if its one of those deep and wide modified bass boats that come up when I put Yamaha g3 model 1652 into google. The max rating of those boats is around 50-60hp. The general rule is to match the boat to a motor that is at least 75% of the max rating, which would be around 40hp. 25 hp should push you along, but you might find it underpowered.
Its sort of apples and oranges, but I find that the 20hp on my 14.5' modified V aluminium boat is the bare minimum to get two +200lbs guys and gear up on plane. The max rating for that boat is 28hp.
