Re: How much internal engine corrosion is too much internal engine corrosion?
No, but the thermostat cover looks like its insides had been sitting under the ocean for about 1000 days. Fortunately, the block doesn't look near as bad.
LOL. i have a engine is so rusted it overheat.. thats the boat that iam working on rigth now..
the first thing i did was remove the intake manifold. and then purchase CLR. that will remove rust. put inside the passage where the water goes to cooled off the engine.. let it rest for a while and then clean it with a long brush wire that dont break so it dont get stuck in the engine..
My Engine was so ruster it was rusted from the inside. so rusted i have to buy 2 sets of Riser...
and purchase a Drill and a Metal Brush to help remove them...
Also Replace your OUtdrive Pump.. AND CHECK YOUR eNGINE WATER PUMP ..
