How much is too much?
Shockley
My boat is rated for 55HP. How do you know how much HP you can go above that? Is 70HP too much?
mikesjet
Re: How much is too much?
55 is the max. There are limits on what the stern can carry or with higher HP actually withstand the push of the motor. In my opinion you are asking for trouble to go over what the ID plate states.
JB
What Mike said.
Shockley
Thanks for the info. I am still going to look in the 40-50HP range.
Silvertip
Honorary Supreme Mariner
There are other reasons for not going over the rated HP. It's called "attorneys" and "Insurance Companies". If you are involved in an incident, your fault or not and an attorney or your insurance company (or both) find out you overpowered your boat someone else will own your equipment and your insurance company will drop you like a hot spud.
kenmyfam
If it states 55hp is the max then it means 55hp is the max. That's all there is to it. Exceeding it is stupidity in my opinion for all the above stated reasons.
scoutabout
Safety-wise, it's not black and white so close to the line. My dad repowered our 1972 Galaxie 15 runabout with a Merc 70 in the mid-eighties, replacing the factory delivered 40 hp. The boat's max rating was 65...but we couldn't find a new 65 hp at the time and went with the next closest...70. Needless to say we were just fine from a safety point of view for the 15 additional years we ran the boat. From a liability perspective, though, exceeding is exceeding and I'm sure a lawyer would have made the most of it had we been in an accident during that time even one completely unrelated to the powerplant.
Don't get me wrong, limits are there for a reason, but I also know enough about engineering to know that, for instance 56 hp isn't going to cause a hull failure or become dangerous on a hull rated for a 55...Where the line truly exists is harder to ascertain and most of the boating public can't be trusted to find out for themselves. Hence the healthy safety margin in the design to compensate. And of course, a hull degraded by age or neglect could be hard pressed to hold together with a motor well under the max.
A semi-related anecdote -- when I was scouring North America for my dream Scout, I had some discussions with a gentleman who had a Dorado 170 with a 115 hp Yammy on it. Curious to find one that wasn't powered by the usual 90, I called Scout boats with the hull ID and asked them if they were familiar with the boat (ah...try THAT at SeaRay...:p)
The great folks there looked it up and indeed remembered building that boat with the special request for more power. Although right at the top of the max hp rating they assured me it was "well within" the hull's capability to handle. I didn't buy that boat for other reasons but it was reassuring to know max hp on that boat does not put it on the edge of safe.)
I know I'm rambling but it's a nice evening, I've got nowhere to be and my wine and canaloni is going down nice. ;)
Fisherball
In Ohio, the ODNR watercraft division ranger would make you shut it off, give you a ticket. make you vacate it & tow it away. It's illegal to exceed stated hp rating & they won't let you use it. They would probably give you a ride to where your vehicle is, but not on a boat with an over hp rated motor.
