How Much Lube In A Mercruiser Alpha One Gen One Lower Unit?
Status
Not open for further replies.
thedukeryan
I thought I had been told that it needed a quart but I have also been told that it should come oozing out the vent plug when completely full. Anyways I pumped a Quart in but nothing came out the vent plug. Should I pump in another?
freeone
Re: How Much Lube In A Mercruiser Alpha One Gen One Lower Unit?
make shure the drive is as level as possible and pump as much as needed to make some come out the top hole, about 1 1/4-1 1/2qts. you are pumping from the bottom hole i assume.
thedukeryan
Thanks for the tips. I did have the outdrive trimmed slightly up so I will make sure to bring it down when putting more in. Yes I am pumping from the bottom up. Another note is that the old oil was dark with nothing that appeared milky. I did not see any metal in the oil but did see some on the drain plug. It appears that the plug is magnetic and picked some up. I would say all of it collected together would probably be equal to half a BB in size. Is this anything to worry about? This is the first time I have done this
freeone
if the shavings are dark nothing to worry about, normal wear.
JimWilson
Why does it drain sooo slowly? Drive is level, vent plug is wide open.
Yellow Yota
Does it have a gear lube monitor? If it does, your capacity is more, as is the method.
Status
