Government cheese
- Joined
- Aug 2, 2015
- 49
The boat is a 1988 GW Invader. It sank a few years ago, (the summer I bought it actually) and has been on the trailer since. It already needs some work, bellows, trim hydraulic hose, bilge blower and a distributor. After it sank changed the oil and plugs, then changed the distributor for a non-marine unit just so I could run it and make sure the motor was ok. Now, three years later, I ran it again and found a core plug out. I put a rubber plug in, ran it, and didn't see any leaks. Now when I went to put the marine distributor back in, the new one had milky oil on the gear. The dipstick has clear clean oil on it. So, it looks like my block (gm350) may be cracked inside.
So, how much do you put in a boat before you decide to let it go and buy a newer one?
