How much oil?
ryanr623
Getting ready to change my oil. Just got the boat. 1976 mercruiser 120. How many quarts does it take? Any reccomended oil?
tommays
Re: How much oil?
It depends on how much you get out and which filter you use :D
You will be in the 4 to 5 quart range
I would pump it out ,replace the filter and put in 4 quarts and after running on the muffs see were the oil is on the stick with the boat level
Fishermark
Re: How much oil?
I don't remember exactly - but it seems like it takes five quarts with a new filter.
Regarding the type - get ready for comments like "Oh no! Another oil thread!" :eek: Things like that. :rolleyes:
You will find quite a few opinions on oil - both in viscosity and brand.
The problem is your original owner's manual probably recommended a straight 30w oil. Mercruiser now has a multi grade they also recommend. DonS has a chart he posts from time to time showing current recommendations.
To paraphrase Bondo's signature "Any oil is better than no oil." Just make sure you change it regularly.
ryanr623
Re: How much oil?
I mean is there special boat oil, or can i use 10w30 for a car?
Uraijit
Banned
Re: How much oil?
I wouldn't use 10w30. As was mentioned, straight 30 was what was originally recommended by Mercruiser. Now, I believe they're recommending 20w-40. I can't find 20W-40 out here, so I use Rotella 15W-40... I don't know if that's the best oil, but that's what I use...
ryanr623
Re: How much oil?
Sorry to be so dumb, I know nothing of oil. Should i use 20w40 or straight 30?
Fishermark
Re: How much oil?
