How much smoke is ok?
tonynoriega2
While testing my 1955 Evinrude Fleetwin 7.5, I am noticing a fairly good amount of smoke. It isn't consistent and only lasts for about 5-10 seconds after start but its there.
I am going 50/1 mixture.
It hasn't ran very much over the past few years so am just wondering if it is kind of "cleaning" itself out.
Also, in my testing tank, there is quite a bit of oily gunk forming around the rim, normal output from old outboards?
thx all.
jimmbo
Re: How much smoke is ok?
I believe that engine uses bushings not needle bearings in the wrist pins. If that is the case then 16:1 would be the recommend ratio. If I am wrong and the engine does have bearings in the wrist pin then the mixture is 24:1.
nwcove
if ya go to 50:1.....the engine will definitely stop smoking in short order. you will destroy it. spend the extra few bucks on high quality oil and stop worrying about a bit of smoke !! jmo
jimmbo
Besides, on cool windless days consider it Mosquito Control
71Windsor
Two stroke out boards were not big on emissions lol. Let her smoke its ok.
boobie
I'd use 24:1 in that motor. And as said above, let it smoke. Besides that it smells good.:)
