Re: How Much Trim Is To Much Trim???
Operating at "running" speeds you should be able to max out the "trim" as high as it will go without doing any damage to the outdrive. Now, the boat may porpoise badly and you may experience control problems, but no damage should result, per se'
My Mercruiser Owners Manual says that when running above the trim range (i.e., using the trailer button) the rpms should be kept below 1000.
I "calibrated" my trim gauge so that I know where the outdrive is positioned. When I'm in the "3/4" up position my skeg is just above the bottom of the boat. I run in shallow water frequently to get to a secluded beach and have never had a problem with the drive (nor ever hit the bottom either).
The bottom line is keep the rpms low and you should have no problem.
