7325johnsonhelp[
- Joined
- Sep 26, 2022
- 31
I'm putting a 1973 Johnson 25hp outboard back into service after many years. I have replaced or rebuilt just about everything, and it runs great in a tank. There is a good bit of water coming out of the top snout with the exhaust, but I only run it for short periods because I'm not sure my water pump is working properly. I'm basing this on the fact that I took the cover off the thermostat slot and removed the thermostat. When I run it like that NO water is coming out of the thermostat hole, either one. When I changed the impeller, I flushed the connection from the water pump discharge in the leg, just to make sure it was clear, and water shot out of the thermostat hole, thermostat removed. I initially installed the new impeller backwards. I pulled it apart and re-did it right but still no water flow through the thermostat. Is it possible the pin in the driveshaft reamed out the impeller or broke and now the impeller is just not turning even though it's installed right? I don't see how it could be working but not be pumping water at a high enough pressure to be blowing out of that open thermostat hole. Anyone with experience with these little motors, HELP. I don't want to burn it up and I'd like to avoid pulling the leg again.
