how much will cost me? So they dont overcharge me!!
betayv
hello there and thanks again I have to send the boat for service and need to know how much around will cost me in parts and labor to replace the gimbal bearing and exhaust bellows thanks.
180shabah
Re: how much will cost me? So they dont overcharge me!!
...couple hundred in parts plus 2-10+ hours labor.
ShaneCarroll
It might be worth it to do the job yourself, if you are able. The cheapest quote I found was about $800 or $900 out the door. You can get all the parts you need for less than $250, and with the vast knowledge on this forum, they'll have you up and running in no time.
arrkerr
Just getting the exhaust bellows replaced was going to cost me about $700.
In all fairness, on an alpha1 gen1 getting everything diss-assembled to the point of replacing the exhaust bellows was a major PITA. Partially due to lack of tools.
To do the job yourself you'll need an engine alignment tool, gimbal bearing install tool, rent a bearing puller (free) from an auto parts store - although the smallest one at autozone wouldn't fit in my bearing, the $10 one from murrays did though - and a tool to fit in the gimbal bolts (or a hex key will fit, but not recommended).
$250 mentioned above is, I believe, a good estimate for doing it yourself, tools included.
Another suggestion is to replace the exhaust bellows with a tube. I didn't know better when I did mine, but the tube can be replaced a lot easier in the future than the bellows.
Do your impellor when you're got the outdrive off. Its another 5 bolts on an alpha1, might as well.
